Curious as to what you all are getting temp wise on your ryzen cpus while gaming and what cooler your using.
My 3600 at stock settings with the stock cooler i saw it hit 83c as the highest temp over a period of 4 hours playing siege online. It stayed between 4 and 4.2ghz this whole time also.
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1082033-ryzen-3000-temps/
