Tips For First PC Build
Go to solution Solved by boey,
This helped me with my first PC build, it may not be the exact same but it'll remind you of what to do so you don't miss anything important out
Pretty good guide for post-build setup.
Hi,
I've picked all the parts for my first budget PC build. I'm planning to upgrade in the future, e.g. more RAM // adding a graphics card etc, but for now, these are the parts:
https://uk.pcpartpicker.com/user/BobThePCBuilder25/saved/#view=BTCZf7
Any tips //  links to good guides for a first time PC builder would be great!
Thanks!! (p.s if someone could have a final quick look through of the parts to see there all definitely compatible, that would be great xD)
https://linustechtips.com/topic/1081433-tips-for-first-pc-build/
4 minutes ago, LukeSavenije said:
bt is a bad idea
ds3h is mediocre
thermaltake h22 is cheaper rn
a400 has quite a high failure rate
All the parts have great reviews
 But I'm planning to upgrade anyway so it doesn't matter to much, but thanks ?
except if you looked a bit closer at them...
the ds3h has a mediocre vrm heatsink at best, even if it does have the same 4C10N and 4C06N as many other gigabyte boards.
the bt has a 30 degree operation, which is horrible, even at a low price
the case i can live with
the ssd is your own risk then
The case is fine for a budget build, "I can live with it" ?. other parts, yeah fair enough. Im not trying to run high end games on it though, any recommendations for better parts?
i havent heard good things about this powersupply as well, maybe you can find a better option, even if youre not pushing it, rather be safe with a better one
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
3 minutes ago, Tamesh16 said:
i havent heard good things about this power as well, maybe you can find a better option, even if youre not pushing it, rather be safe with a better one
i mean... with 40 degree operation it's considerable, but 30 is horrible
6 minutes ago, LukeSavenije said:
system power 9 and cxm 2015 seem to be priced quite well rn
How about this? Corsair CP-9020101-UK CX450M 450 W 80+ Bronze Certified ATX Power Supply Unit https://www.amazon.co.uk/dp/B01C3FFOHS/ref=cm_sw_r_cp_apa_i_zzhkDbQJP98WM
that's the cxm 2015 i mentioned...
tho the be quiet system power 9 seems to be cheaper rn
Just now, NewBuilder01 said:
Yeah cool I'm glad it's the one you mentioned I found it before I read your message ?
i actually personally have one, the 550
mine whines tho, but that has more to do that it's double forward and i put a 1070 ti on it
Before starting your machine for the first time.
Connect to wall outlet
Turn wall outlet on
Turn on PSU
Ensure CPU power cable is connected
Ensure monitor is connected to wall outlet and outlet is on
Ensure monitor is connected to PC
Ensure Monitor is set to correct source
These tips will save you from the biggest “OH GOD NO” moments every PC builder experiences.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
