First build in a long while so kinda relearning all this just got in everything today. Trying to use am x470 asus vii hero but I keep getting a post code of 8- not 08 just 8. Also I'm not sure if my bios flash is taking or not as it flashes and then goes solid. Pls help
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
    Corsair pro rgb 16gb 3400 oc stock timings
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
    My digital ssd 250gb pro m.2 (boot) 2tb berracuda 7200rpm +Toshiba x300 4gb 7200rpm
  • PSU
    Evga g3 750
https://linustechtips.com/topic/1081286-need-help-8-post-code-error-ryzen-3700x/
I wouldn't have a clue
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
Plus the crosshair is supposed to be a compatable board
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
You have to update the board with the newest bios update before it will work and most boards need a CPU in to flash the bios, so you might need a Ryzen 2000 CPU in the board for the update to work.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
The asus board has a bios flash back were I don't need a cpu but I can't get that to work ether
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
Also make sure your flash drive with the bios update is plugged directly into the usb 3 port on the motherboard and not one on your case.
Hmm have you tried clearing CMOS and trying it again?
Did that. Tried 3 different usbs and dosent matter what bios I put on it they dont flash. It blinks for about 3 seconds then goes solid
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
Are you trying BIOS 2406?  Did you use the tool in Windows to re-name the BIOS?  Did you use the USB port labeled BIOS?  Have you used that USB stick to update BIOS before?  If not then is it formatted FAT32?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
Well I got my answer stright from asus apperently the x470 vii hero dosent have a straight up flash back system that nothing but there ez flash system so no I need to see if ryzen can ship my a processor and waste the thermal paste on my aio. Thank asus.....last time I buy a product from them
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
Anyone know where the ryzen OPN nimber is?
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
Ummmm.   It does.
Edit:
Wait, what are you saying?
Edit 2:
And did you see my earlier post?
27 minutes ago, nick name said:
Ummmm.   It does.
Edit:
Edit 2:
Ibdid see your post and in order of ask
Yes,yes,yes, technically no because apperently my first attempt was also a failure, and formatted to fat16 and fat 32
And acourding to asus rep only way to update bios is with a different cpu.
And nothing personal but unless someone with the same mobo I'm currently having issues with suggests something at this point I'm sure if tried the rest of the ideas you guys can spit ball at me.
Looking for concrete responses not guesses please
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
I have the same mobo
I have the exact same board. All you need to do is download latest bios AND the tool needed to rename the bios. Also pretty sure to do the flashback you need to take out CPU/RAM. This board indeed supports bios flashback. Unlike the old haswell days there should be no need to have an old cpu. As those bios updates had to be run in windows for some reason...
Got it working finaly. Asus has some shoddy service reps....but I do have a new issue my g502 mouse dosent work in bios but works in windows. Only thing that works is scroll wheel which causes cursor to jump from right to left across screen other than that I get nothing
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
That's a bug in the latest BIOS for several ASUS boards.  They will fix it.
Cool. Had any issues with PBO at all?
None that I've seen. My blk clocks got wonkie out of box and my cpu and ram voltages were way to high but brought those down in bios. Gonna try just undervolting as setting all core boost compared to precision boost perf is negligible at best it seems on ryzen3k. Then oc ram try to get as high as I can with out really changing timings as I dint quite understand how to do timungs yet
  • CPU
    Ryzen 3700x
  • Motherboard
    Asus rog hero vii
  • RAM
  • GPU
    Radeon Vii
  • Case
    Thermaltake G21 TG
  • Storage
  • PSU
    Evga g3 750
