The video where you used an external water cooler and the coolant lines where condensating heavily, I was thinking of ways to encase it and remove all the moisture. Vacume and pressure are out of the question. Then it dawned on me. Dry nitrogen... Readily available and works at room pressure.... And if automated purging is needed, thats easy.
https://linustechtips.com/topic/1081249-water-cooler-maxout/
21 minutes ago, Firewrath9 said:
then the nitrogen will cool down and whatever you put to contain the nitrogen will condense...
Not liquid nitrogen, room temperature dry nitrogen from a pressurized gas cylinder. Displaced the atmosphere with pure nitrogen.
https://linustechtips.com/topic/1081249-water-cooler-maxout/#findComment-12711460
yes. room temperture nitrogen. The fluid in the tubes will cool down the tube which will cool down the nitrogen.
https://linustechtips.com/topic/1081249-water-cooler-maxout/#findComment-12711464
But no water to condensate on the inside. So it's safe for the electronics. Therefore you can run your chilled water at tempatures well below the dew point using a compressor driven water cooler.
https://linustechtips.com/topic/1081249-water-cooler-maxout/#findComment-12711477
so the entire system is in nitrogen... suppose you want to use the safe boot button...
https://linustechtips.com/topic/1081249-water-cooler-maxout/#findComment-12711561
It would require occasional purging but this is possible however having a case that is very open air in this kind of application wouldn't work and would need to be fairly isolated with the tubing and rad running out to somewhere else.
This is commonly used on industrial equipment with clean air or liquid air tanks to purge cabinets but to prevent dust ingress.
https://linustechtips.com/topic/1081249-water-cooler-maxout/#findComment-12711622
