Help
Go to solution Solved by AndrewB121,
12 minutes ago, AVSHedgehog said:
thx well it be good for r6s as well?
I should think so. Check some benchmarks (Hardware Unboxed are good) to see what it will run each game at.
Not the best cooler but can defo do 1080p 144fps and will probably overclock well enough.
CPU: AMD Ryzen 5 2600X  |  Cooler: Cryorig H7  |  Motherboard: MSI B450 Mortar  |  Case: Fractal Design Meshify C Mini  |  RAM: 32GB DDR4 3000MHz  |  GPU: EVGA 1070ti Gaming (Kraken G12 Watercooled) |  PSU: Corsair TXM650  |  Storage: Samsung 860 EVO 500GB + WD Blue M.2 500GB  |  Network Card: Asus PCE-AC56  |  Monitor: Acer Nitro VG270U  |  Audio: Sennheiser HD6XX + Schiit Fulla 2
Laptop:
Lenovo s540:  CPU: AMD Ryzen 5 3500U  |  RAM: 8GB DDR4 2666MHz  |  GPU: AMD Radeon Vega 8  |  Storage: 256GB NVME SSD
https://linustechtips.com/topic/1081123-help/#findComment-12710308
Laptop:
https://linustechtips.com/topic/1081123-help/#findComment-12710350
