What exactly is the problem with your new case fans?
-Moved to Air Cooling-
https://linustechtips.com/topic/1080924-case-fans/#findComment-12708974
Just now, SHG_Marsh said:
I bought them and one fan just doesn't work and the remote is also broken so I can't change the color/settings of the fans.
I'm assuming you're going to refund them?
Also, do they have to be RGB? What size are you looking for?
https://linustechtips.com/topic/1080924-case-fans/#findComment-12708986
they are 120 and I am going to refund them.
I have four Corsair AF120s in one of my builds. They're not RGB, but I think they had one line that was...the name escapes me at the moment but I have a friend that bought I think it was a triple pack of them.
https://linustechtips.com/topic/1080924-case-fans/#findComment-12708995
where did you find a triple pack?
https://linustechtips.com/topic/1080924-case-fans/#findComment-12709015
