20 minutes ago, marcolvz said:
any thoughts on this? http://prntscr.com/od74b4
wanna make sure i'm making a good purchase
That’s a decent start especially if you want to expand and add in a GPU. For the pump you would be better with a DDC or ideally a D5 pump which is regarded to be the best. As for tubing go for thick walled 3/8ID 5/8OD tubing as it doesn’t kink as easily.
ty very much✌️
