High "System" Usage
Solved by .Apex.,
9 minutes ago, Moonzy said:indeed it is
does it have to do with AI Suite?
it's possible, AI Suite messes with many things I never recommend it, You can try uninstalling it, and then try updating your Chipset drivers from here https://downloadcenter.intel.com/download/28182/Chipset-INF-Utility?product=46644
If it doesn't work then you can also find ACPI drivers in Device Manager under System Devices, try manually uninstalling all ACPI stuff, there's also Microsoft ACPI if you scroll down, and then restart your PC, Windows will reinstall them again
