I purchased an Adata XPG SX8200 Pro 1TB for the computer I'm currently building, and I was wondering what you guys think about cooling it or not. It comes with a heat sink, and the motherboard I bought also comes with a heat shield (the Gigabyte X470 Aorus Ultra Gaming). Would you guys use the drive's heat sink, the motherboard's heat shield, both, or none at all? The M.2 slot is also located under the graphics card. What do you all think? Thanks!
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/
which heatsink has more surface area? Only use one heatsink at a time.
Desktop benching:
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12698247
@Jurrunio Probably the one that came with the motherboard? Do you mean how much comes into contact with the drive, or how large it is? Sorry for noob questions. I've read that these things are just sales gimmicks and a lot of the time do more harm than good.
I'd love to hear more opinions on the matter, and thanks!
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12698967
how much contact area it has with the air. This determines heat dissipation.
Desktop benching:
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12699130
14 minutes ago, ShafeDogg said:
@Jurrunio Could you explain more about it? Do you personally suggest using any type of M.2 cooling?
I'm still on the fence about it honestly, so any suggestions are greatly appreciated!
Basically, to get more cooling, you increase surface area. Deep cuts on an aluminium block, fins, do the best. In this case neither are present but you should still use the one with more cuts on it.
Desktop benching:
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12700708
Here is a question along those lines.  The heat sink that came with my MP600 bumps up against the shroud on the ASUS ROG X570-E mobo.  So my options are to modify the shroud, or use the heat sink that came with the mobo.  Is there any data for which heat sink is more effective, or are they essentially equivalent?  The MP600 stock heat sink has the deep cuts that Jurrinio mentioned, but the mobo heat sink sink is larger, and heavier.  Does anyone actually have any real world data?
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12710300
This is a lot of overthinking for a M.2 SSD.  Just install it and be done.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12710307
As I said, I can't just install it because the shroud is in the way.  I either cut the shroud and keep the MP600 heatsink, or I remove it and use the mobo stock heat sink.  So i was wondering if anyone already had data on which was a better option.
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12710324
Use the motherboard shroud, it'll look better.   Either one is fine, it's your call 100%.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12710330
i wouldnt say those things absolutly need any cooling at all. mobo manufacturer cover them to not have a potential competing brand name visible on the board and obviously for marketing purposes.
so if youre asking functional difference only i would say it doesnt matter and you could probably even run it without any cooling.
and the rest .. well thats just personal preference and taste on what looks better to you.
id use the mobo piece just so it looks cleaner.
but then again i wouldnt have purchased an ssd from a brand that markets it with a "cooler" but that just me
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12710346
All the pcie gen 4 nvmes are coming with coolers attached to them right now, so it would be the same problem with any of the currently available gen 4s. So I am guessing cooling is more important than it was with gen 3.  Maybe i'll just have to test it myself, if nobody has any data already
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12710404
  • 2 weeks later...
@jinzaburou Honestly it's going to be a long time before I even think about using PCIe 4.0. Until the technology is able to be used without a fan on the motherboard at a minimum. Everyone is jumping on the bandwagon to use this technology, but it's still generating too much heat, and enough parts need cooling or fans as-is. Not to mention video cards can't even utilize so much speed. It's just another expensive thing to go wrong, and this time it's attached to your motherboard. I would guess that's why the new NVMe drives are needing more cooling as well, as they are near the PCIe lanes.
https://linustechtips.com/topic/1079531-nvme-optimal-cooling/#findComment-12738471
