Hi, Welcome to the fourms!
What are you using this pc for?
Budget
size requirments.
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696816
Budget
size requirments.
A Ryzen 3 will go well with a RX 560
Its a good system for under 400 bucks.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696821
yes it will work.
any reason picking the 2200g?
2400g already cheap. and there will be 3400g soon.
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696822
Just now, Turtle Rig said:
A Ryzen 3 and no video card ?  Grab a 1050Ti or a used RX 560 to match your cpu and not cause a crazy bottleneck.
Hey, thanks. yeah the Ryzen comes with Radeon Vega 8 graphics, is that enough? I was thinking I might need a card aswell. Its a mid range pc im going for
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696827
2 minutes ago, SupaKomputa said:
yes it will work.
Hes right just wait one day LOL!
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696828
The key is picking a video card that goes well with the CPU.  I wouldn't get anything higher then a AMD RX 560 and with nVidia I wouldn't go higher then a 1050Ti.  But also depends on what games you play.  CS:GO will be really butter smooth and fast where as a modern AAA titles will get taxed.
well then... xD I am trying to keep the budget though, soo, i guess ill check the price, thats the only reason I picked that TBH, it came with a good bundle deal
Plus prices of the CPU you picked will fall after tomorrow if you insist on that CPU. But 3400g will be a good price on release.
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696832
Ah okay, so your saying every things fine, I just could upgrade the CPU, and ill look into that xD but also I should get a graphics card, 1050Ti?
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696841
no... 1050ti is dead.
get a used rx570.
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696845
Pcpartpicker.com is the best way to share a parts list, replace the one in the OP with a PCpp list permalink. It has the lowest pricing available from a lot of retailers as well.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696849
get a used rx570.
I was just saying nVidia side of things ya know.... But ya used 560 or 570 def...
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696850
Sorry Im new to this, but do I actually need a graphics card if the CPU has Vega 8 graphics already, could I run games well without an extra graphics card?
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696854
with new RX570 at 100ish, i really can't recommend any other budget gpu, it's just too good.
waiting for vega 56 to dip below 200...
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696855
running them well? not really, the Vega 8 solution is for 720 medium basically. If you get an Rx 470 or 570 from ebay, it's miles better.
check this out:
I included the new GPU but used is always more economical.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696859
yeah you're right. but if you wanna game with a proper fps in 1080 get a gpu.
otherwise if you're content with 720p gaming, it's playable enough.
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696860
check this out:
Perfect, thanks!
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696861
1 minute ago, NewBuilder01 said:
Perfect, thanks!
Also, if you'd like to save even more
https://uk.pcpartpicker.com/product/dQgzK8/asrock-b450m-pro4-micro-atx-am4-motherboard-b450m-pro4
This motherboard more than gets the job done. Plenty of power phases with a proper heat sink, and very affordable.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696869
26 minutes ago, NewBuilder01 said:
areyou sure you will be good with a cpu that works as a gpu too?
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696871
what's the problem with that? intel cpu have gpu too...
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696875
why don't you just try if first without the GPU.
yes it will work with an extra gpu, you can get the gpu anytime.
https://linustechtips.com/topic/1079315-building-first-pc/#findComment-12696885
