well my pc is new i build it and it working fine in windows but when i play games my gpu usage is going up and down from 88% to 0%
Cpu usage is 45%-65%
and my fps is droping because of that.
Specs:
CPU:Ryzen 5 2400g
GPU:Amd rx 480 8gb
Motherboard:Asus prime a320m-k
Ram:hyperX 2x4gb 2666mhz
ssd:Gigabyte  240gb
https://linustechtips.com/topic/1079287-gpu-usage-going-up-and-down/
New PC? Your 480 reached 90c even when not on constant 100% load. Check if the fan is working or return it.
I wouldn't consider this a problem unless there's serious hitching or hiccuping going on.
All GPU utilization is is how often in a sample period (probably 1 second in this case) the GPU was given something to do. It's not always indicative of performance loss.
