Low performance
Solved by PopsicleHustler,
Just now, Dragooo said:Should I buy Better RAM then is it the whole problem?
Your RAM could be a part of the issue. As @mariushm said, R5 2400g is 4c/8t CPU which migh be a limiting factor when paired with high end GPU, especially at high FPS. Current lower end Ryzen CPUs are not really capable of pushing high FPS numbers, which is evident by its usage in R6S.
