when i play cs:go on low settings everything i get around 80-100fps when expected from my graphics card is 150+fps  at all times on high settings. this also applise to fortnite i have only textures and view distant max and when i glide or when im in a fight i get like 80-100fps and lots of lag spikes down to 40fps. i have updated my drivers and overclocked my graphics card as well.
my rig:
GPU: asus gtx 1060 6gb pheonix fan edition
CPU: ryzen 5 2400 with vega radeon graphics
PSU: thermletake 400w litepower
RAM: 8gb ddr4 teamgroup vulcan red
MOBO: Asus PRIME A320M-K
https://linustechtips.com/topic/1078754-why-such-low-fps/
28 minutes ago, EightySixedKyle said:
Probably your PSU. I would go for a 600w 80+bronze.
I extremely highly doubt that is the case here. Far more likely OP's being held back by the CPU+RAM.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/1078754-why-such-low-fps/#findComment-12692955
I want to second this.  unless the psu in question is absolute crap and i mean absolute crap then it should be fine for a 2400g and a 1060 6gb as peak power-draw for both of these is sub 250 watts underload. Likely a cpu bottle neck in my opinion, id recommend OP actually increases their graphics settings as unless they are using a high refresh rate panel they wont be able to see those extra 30 frames anyways so you might as well get some better looking graphics
https://linustechtips.com/topic/1078754-why-such-low-fps/#findComment-12692982
just a quick question what do you mean by OP?
https://linustechtips.com/topic/1078754-why-such-low-fps/#findComment-12698287
you say the cpu is the bottleneck if it is then i should i upgrade too?
https://linustechtips.com/topic/1078754-why-such-low-fps/#findComment-12698960
Going to ask cuz no one else did:  Is your monitor plugged into the onboard video or GPU?  Never hurts to verify.
Is your RAM single channel or dual?  What speed?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1078754-why-such-low-fps/#findComment-12702139
You were just a little bit faster than me, just wanted to ask the same things hehe
https://linustechtips.com/topic/1078754-why-such-low-fps/#findComment-12702145
its plugged into the gpu and ram is 2400mz single channel
https://linustechtips.com/topic/1078754-why-such-low-fps/#findComment-12724774
my rig:
It's probably the PSU. I have seen cheaper thermaltake units not supplying enough power to the GPU. Upgrade ur GPU to some decent unit.
GOLDEN CAT
Ryzen 5 2400g
Asrock AB350 PRO4
Gskill Ripjaws 4*2gb 3000mhz
HP EX920 512GB
Seagate barracuda 2000GB
Zotac 1080ti Amp Extreme
Fractal Design Meshify C
Cooler Master Masterwatt 550
https://linustechtips.com/topic/1078754-why-such-low-fps/#findComment-12724903
