Fans Running at High RPM
Solved by TheKDub,
9 minutes ago, LuX_ said:What software do you use to do that because my fan control in my bios is very restrictive and doesn't have an option for 'turn off until _' and the lowest I can set them to is 50% @ 40C. There is a grey square which I have no control over which I'm assuming is the below the bottom one I set and it is stuck at 60%
I use ASUS' AI Suite 3 (for ASUS motherboards). You'll have to use MSI Command Center for in-windows control over your fan curves.
