So im currently looking into rebuilding my pc from my shitty Cooler master HAF X into a DarkFlash Phantom. Curious on anyones thoughts of the brand? is it a good quality brand? i came across an RGb fan of theirs once to resell, and it seemed very high quality, the case is full glass and everything, and they have a DT240 water cooler i want to get to go in it, just curious if anyone has had good or bad experiences with them? Thanks
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
https://linustechtips.com/topic/1077812-darkflash-phantom-thoughts/
