so i was wondering if something like this exist or if not how else i could realize it.
the problem is my parents are getting older and lately i noticed they are cranking up the volume on the tv to hear better.
i thought if there was a cheaper-ish solution where i could hook a transmitter up to lets say the aux / headphone port of the tv (since the tv is a bit older im almost certain it doesnt have bluetooth) and then have a soundbar receive and play the audio. i could just place the soundbar behind at ear height behind the couch and so they wouldnt need to crank up the volume as much.
now thinknig about it im a bit worried about lag but i think with aptx or something that should be fine right?
anyway does someone know of a product like that or how i could patch it up myself to achieve this?
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
https://linustechtips.com/topic/1077675-wireless-soundbar/
44 minutes ago, JabroniBaloney said:
Did you Google "wireless soundbar"?
duhh but i only see combos with wa wireless sub or wireless rears but nothing where the bar itself is wireless. some have bluetooth but none come with a aux in transmitter.
really i thought it would be possible. its basically the same thing as a pair of wireless headphones. for home entertainment those often come with a base station. so why not the same thing but with a speaker  on the other end instead of heaphones
https://linustechtips.com/topic/1077675-wireless-soundbar/#findComment-12684810
