Hi, so I'm in the market for a good laptop for some casual gaming use. I immediately thought about the Razer Blade 15 as i like the stylings and stuff but when I looked I saw there 2 models. I've done a bit of research but don't know if the advanced version is too much for what I need (also it's really expensive). For it to be able to play Forza Horizon 4, R6, and Apex at a good quality is all I really want it to do. I don't really care about getting the max fps or anything just as long as its playable. Is the base model ok or do I want something more? (would also be used for college work and watching youtube and stuff if this helps) any advice appreciated thanks.
https://linustechtips.com/topic/1077546-razer-blade-15-basic-or-advanced/
The "Basic" blade 15 is a very different laptop, built cheaper and has lower specs as well as a different port selection (IIRC on that last one). Though, for the massive price difference between them I would still recommend the Basic.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
For the smaller one, I agree, the port selection is actually better on the basic fyi. i don't think 240hz has a point to it unless you are a pro gamer.
and OP, seeing that you are looking at either model, i am guessing that is a no.
fyi i am going through this myself. you may want to check out the hero 3 from asus also. Personally I am looking at the pro 2019 from razer. Search my profile to see why if you care.
