I need some help
Go to solution Solved by rice guru,
3 hours ago, Perkz said:
Im planning to buy the Monoprice Modern Retro Audiophile headphones, and I was just wondering if I needed a DAC to use it properly?
No you don't need a dac or amp to drive the thing . Only consider an amp and dac if your source is too noisy or if your headphones are not loud enough. At 50 ohm they are plenty efficient and should be able to be run off your phone or desktop. I would recommend grabbing new replacement pads instead
Depends on the sensitivity of the headphones I think what you're asking is if you would need an external amp for it.
Is this it https://www.amazon.com/Monoprice-Ultra-Comfortable-Modern-Retro-Headphones/dp/B01M7Z0VKR ?
You can bark like a dog, but that won't make you a dog.
You can act like someone you're not, but that won't change who you are.
Finished Crysis without a discrete GPU,15 FPS average, and a lot of heart
How I plan my builds -
For me I start with the "There's no way I'm not gonna spend $1,000 on a system."
Followed by the "Wow I need to buy the OS for a $100!?"
Then "Let's start with the 'best budget GPU' and 'best budget CPU' that actually fits what I think is my budget."
Realizing my budget is a lot less, I work my way to "I think these new games will run on a cheap ass CPU."
Then end with "The new parts launching next year is probably gonna be better and faster for the same price so I'll just buy next year."
https://linustechtips.com/topic/1077133-i-need-some-help/#findComment-12680903
Yeah, thats the one
https://linustechtips.com/topic/1077133-i-need-some-help/#findComment-12681127
https://linustechtips.com/topic/1077133-i-need-some-help/#findComment-12681182
Thanks man! I'll look around for some pads.
https://linustechtips.com/topic/1077133-i-need-some-help/#findComment-12681259
