Try this. It's for the Ryzen 3 2200g, but the steps are pretty much the same. But in all honesty, it's not worth overclocking the 2700x anyways.
Motherboard: MSI B450m Mortar Max
Processor: Ryzen 7 2700 w/ Wraith Prism
RAM: Klev Cras X 3200mhz 8gb x2
GPU:  Zotac Mini GeForce GTX 1070ti 8GB
PSU: Seasonic GX-750
Case: Inplay Robin 101 + 10 fans w/ hub and remote
Storage: Toshiba 1TB, Western Digital WD Green 1TB, Crucial BX500 480GB
17 minutes ago, ABK-RaY said:
i have ryzen 7 2700!  65W TDP
not 2700X
Oh then I guess it's worth overclocking then. Just go follow the video since it's pretty much the same process, and try this for your inputs:
4.125 ghz voltage - auto (1.415V)
You can always change the ghz and voltage anyways if ever something goes wrong. Hope this helps.
Whats the point of making a static OC at 4.125ghz and 1.415 volts? I mean your better off leaving everything on auto if you are not using voltage offset or at least under volting. The best thing you can do with the Ryzen CPUs is overclock the memory speed and have better timings
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
