I am soon going to change the thermal paste in my gtx 1080 amp extreme.. i am nervous as to which method amd how much to use in order to cover full gpu dye but not overuse.. is spreading with a small plastic tool better? Or just a blob in the middle.. also if after reassembly the paste inside dosnt touch the while die amd some corer gets left out.. what happens?
https://linustechtips.com/topic/1075742-gpu-thermal-paste-change-help/
When it comes to GPU's TIM swap, I subscribe to the "excess is fine (within reason), if you don't know what you're doing" method. So long as you're not using a conductive TIM (ergo, anything modern that isn't gallium based/liquid metal should be non conductive), a bit of overflow excess shouldn't be a problem beyond being a bit messy.
You can absolutely spread it over the die if you'd like.
Should your replacement TIM fail to spread out across your entire die it can (likely will) create a hotspot that will eventually cause the card to fail.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
Is there a reason you're changing the paste?  You seem nervous about it and while I am all for doing and learning, they're not a maintenance item.  Paste is still good for years.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
3 minutes ago, Semper said:
When it comes to GPU's TIM swap, I subscribe to the "excess is fine, if you don't know what you're doing" method. So long as you're not using a conductive TIM (ergo, anything modern that isn't gallium based/liquid metal), a bit of overflow excess shouldn't be a problem beyond being a bit messy.
Some posts are saying spreading air bubbles etc etc.. aur bubbles van also cause hotspots right?
The card is running hot.. and i wanna put in a better compound for some gains
Theoretically, yes. Air bubbles have never been an issue in any of my experiences however. I don't know that I've ever read of issues relating to air bubbles either.
If air bubbles cause an issue, it's likely that you didn't have adequate mounting pressure as a precursor.
a 10xx series card shouldn't be having issues with TIM this early. It may be a limitation of your cooler design, your environment, or the airflow in your case, in which event a TIM swap likely won't see any improvement. Before you pull the card apart, do some research on your card, see if it's a known issue. Also assess your airflow, see if that can be improved (a quick and dirty way to check this would be to remove your side panel and run as you would normally, see if there's any improvement.
Okk will try.. but in case if i change.   Should i go for spreading method? Should i freak abt air bubbles if i change tim and use zoread methid.. because to be using the drop method and having a part of the die left out sounds a bigger problem
I get the impression that no matter what I say here, you're going to be concerned that you've done it incorrectly.
Pick a method and go with it, don't be unreasonable with how much (or how little) you apply, and trust yourself.
Again though, do some research and/or check your case airflow before you pull your card out.
Okk tell me personally which method u would go with.. ?
So long as you have enough TIM, application method makes no difference. Pick one and roll with it. I use the dot/pea method because I'm lazy, but I've also been doing this long enough that I can reasonably estimate how much is needed.
When I first started, I spread it with a tool. When I lost the tool, I used my fingers.
When I got a little more lazy, I moved to the "X" method.
When I got even more lazy, I arrived at the dot/pea method.
