MOBO RGB header Splitter
Go to solution Solved by bluebuffalo831,
Ya
I have an Aorus Gaming 7 WiFi MOBO it only has 2 x 12v RGB headers.
The first one is used by a 3 way splitter for RGB fans and the other has my rgb strip.
My question is I’m getting three more RGB fans,  and I was wondering if I can get this splitter it’s an eight way splitter and put all my fans on that splitter will just overload my system like fan headers?
https://www.amazon.com/black-Splitter-Connector-Strips-wire,10x/dp/B075FKL6C1/ref=sr_1_13?gclid=CjwKCAjwxrzoBRBBEiwAbtX1n0HTB7XDDs_ubK0QFV3vJx-ngmXOIQ0sd8VF2oUObOH7fm4fC3rtOxoCOHAQAvD_BwE&hvadid=323392947331&hvdev=t&hvlocphy=9023613&hvnetw=g&hvpos=1t1&hvqmt=b&hvrand=13477711569356586778&hvtargid=kwd-600625982287&hydadcr=21778_9711354&keywords=rgb+splitter+cable+4+pin&qid=1561336467&s=gateway&sr=8-13
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
https://linustechtips.com/topic/1075529-mobo-rgb-header-splitter/
Just now, bluebuffalo831 said:
It could I would recommend getting a hub
All my power for the fans are running to a SATA
My PC:
My Kids PC:
Also 2A max on rgb header so I just calculate all the fans amperage
My PC:
My Kids PC:
So my fans are 0.40 Amp so 5 fans per header?
My PC:
My Kids PC:
