Hi, am current planning on building a new PC from scratch.
Aim is to be able to play games on 1080p~1440p with a min stable 60fps.
Games would included:
-Newer AAA titles such as AC odyssey, Destiny 2.. etc
-Future AAA titles like Cyberpunk 2077
-Older titles such as Witcher 3 etc.
Country: Malaysia (MYR)
Planning to run on at max 2 monitors: 27'' 144hz for 1 and the other will be a standard 24'' 60hz
I've already chosen the parts with some probable changes in light of the new announcements made for the Ryzen 3000 & the RTX super cards.
Here's the list of the parts I've chosen from the options available at my local store:
Official list from store: IDEALTECH PC BUILDER.pdf
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor (MYR 820)
CPU Cooler: CRYORIG - H7 Quad Lumi 49 CFM CPU Cooler (MYR 229)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard (MYR 709)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory (MYR 649)
Storage: Gigabyte - M.2 NVMe PCIe 512 GB (MYR 359)
Storage: Gigabyte - M.2 NVMe PCIe 256 GB (MYR 219)
Video Card: Gigabyte - GeForce RTX 2060 6 GB GAMING OC Video Card (MYR 1,899)
Case: Corsair - Crystal 460X RGB ATX Mid Tower Case (MYR 619)
Power Supply: FSP Hydro PTM 650 (80+ Platinum/Full Modular) (MYR 499)
Total cost: MYR 5,942
Approx: USD 1,436
Might plan to swap:
RTX 2060 to a RTX 2060 super
Ryzen 5 2600x to a Ryzen 5 3600x
Would like to build to also be somewhat future proofed for the next 4~5 years if possible.
Advice needed includes:
1. Are any parts chosen somewhat of an overkill?
2. Any changes required due to compatibility issues?
3. Should I just wait for x570? xD
Thanks in advance guys :D
https://linustechtips.com/topic/1075347-advice-on-planned-build/
No obvious compatibility issues I can see
If you can wait, would recommend maybe pickup the 3600x with an x570 board.
If you really want it to be able to last many  years, would recommend you get a 3700x instead, should handle anything you throw at it.
But the graphics card can't really be future proof, as games just get more and more demanding + graphics cards advancements are pretty big. so maybe the RTX 2060 would last you 3 years or so, after that just replace it with a mid range tier card of the generation then.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
