Better than my PC.  When it's unplugged I can't even turn it on.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
2 minutes ago, Vulkan HeStan said:
Sounds like power saving or something. Go into windows power settings and change performance when running from battery to "best performance"
It's not on power saver, it's on best performance. I've already tried setting my CPU maximum usage to 100% but its still limited to 13% usage.
What happens when you're doing something and you unplug in the middle of it?
Primary PC:
PSU tier list
How many watts do I need?
Now I'm beginning to understand. OP you need to actually ask a question about your problem, rather than just make a fucking statement.
Anyway...
Do you know if your battery is any good? If it's not able to provide the right amount of voltage, it could be the reason that on battery you see limited performance.
Anyway...
Well, sorry for making a statement.
I've used the same wall charger for a long time.
This is way too vague to answer. There's no question. What's the problem? When does it occur? What does it do? What can we do to help? What troubleshooting methods have you done already? Basic things you need to tell us if you need a problem sorting. All I've figured out is your CPU utilisation drops when not charging, which is perfectly normal. So far I don't see the issue.
You've got to bring the issue to light, explain the problems you have and with what. Otherwise it looks like a status update and a mod may have shut the threat down for it.
If your CPU runs at 100% while plugged in, I wouldn't think the charger is the issue. But I guess it could still be a factor. I think your battery may need to be replaced. Does it seem like it discharges a lot faster than it used to?
Ok, let me rephrase if I can.
My laptop's CPU usage is maximising on 13% abnormally when it's unplugged. It usually maximises at 100%.
Before this happened. I connected a Bluetooth speaker to my laptop and ran some music. Then I closed my laptop and my speaker disconnected automatically and I was gone for 10 minutes. When opening my laptop after 10 minutes, my laptop started being really slow.
I've tried troubleshooting it,
making a new power plan
and restarting it.
and restarting it.
How could I restore my original power usage (100%) when it is unplugged?
I think what we are trying to say is you need to be more specific. What do you mean by "setting" the cpu usage? The computer will only use teh amount of CPU needed to preform the tasks it needs to do. At idle, meaning its just sitting at the desktop with no programs open, you should be seeing around 0-15 percent. Are you using special software to set maximum CPU usage? If so what software? Could you run a program that will scientifically demonstrate that it is running slower on battery power that it's supposed to, like a benchmark? Try running a stress test like prime95 and looking at task manager and seeing what the CPU usage is. I know I just asked a lot of questions, but these are all things that would significantly help us figure out what your asking.
1 hour ago, LaN_TeN said:
it lags when I unplug it
How is the battery usage affected by restarting the PC? Is it always limited or does it come into effect a certain period after boot?
Primary PC:
PSU tier list
