Hello guys I tried to launch Fortnite and PUBG it loads for like few minutes then my pc restarts and I get an error that says Power surge has ben detected by Asus anti surge.
Now I have 300w psu.
How much watts do I need for my build:
i5 2500 3.3ghz
RX 560 4GB
RAM 4gb + 2gb ddr3 1333mhz
https://linustechtips.com/topic/1075216-power-surge-detected/
i5 2500 3.3ghz
RX 560 4GB
Asus Anti-Surge is 99% bullshit.
That said... WHAT "300w PSU".
Some are 300W PSUs.  Most are not.
https://linustechtips.com/topic/1075216-power-surge-detected/#findComment-12665129
i5 2500 3.3ghz
RX 560 4GB
it's a unstable psu and it isn't enough power
https://linustechtips.com/topic/1075216-power-surge-detected/#findComment-12665150
Wow!  You were able to determine that from OP's post????
Asus Anti-Surge is hot garbage:
https://www.overclock.net/forum/31-power-supplies/1552794-asus-anti-surge-broken-mess.html
https://linustechtips.com/main/topic/938835-power-surge-detected-despite-very-good-psu/
https://steamcommunity.com/discussions/forum/11/412446890547210003/
That said, if OP knows he has a 300W PSU but doesn't even know what brand it is, it's probably as hot garbage as Asus Anti-Surge.
https://linustechtips.com/topic/1075216-power-surge-detected/#findComment-12665163
4 minutes ago, Mattsk said:
it's facts
You can't declare something as a fact, especially if they aren't true.
5 minutes ago, Mattsk said:
everything he has in his pc is near taking up all his power
A GPU powered through just the PCIe slot and a locked quad core? That's not going to draw anywhere near 300W. Also, again, what lead you to the conclusion that the PC is using too much power?
7 minutes ago, Mattsk said:
and he must have a weak psu if he's getting that message
The message can come from any shutdown. It's known for false positives. Again, what lead you to the conclusion that a weak PSU causes that message?
https://linustechtips.com/topic/1075216-power-surge-detected/#findComment-12665200
Ahhh it uses 6pin sata connector
https://linustechtips.com/topic/1075216-power-surge-detected/#findComment-12666227
We can't help without knowing what model of PSU you have. "300w PSU" doesn't provide enough information to be able to help.
If you're unsure what model it is then post a photo of the label on the PSU.
SATA power connectors are the thin flat connectors that plug in to hard drives, SSDs, and sometimes some other devices such as fan controller hubs.
The 6pin connector for graphics cards will be a 6pin PCIe connector.
If your graphics card has a 6pin plug on it, does your power supply have a 6pin PCIe connector to plug in to it? Is it plugged in?
https://linustechtips.com/topic/1075216-power-surge-detected/#findComment-12666569
