I hate wires. If you could see my set up you would think everything is wireless but my mouse. I couldn't fond a convenient sot to put my mouse wire. Sometimes the wire gets stuck under my desk. I want a wireless mouse but I dont really want to spend over 100 if I don't have to. I was looking at the razor lance head. I do know that Bluetooth mice is iffy because of latency but if I can get a wireless mouse that is almost as good at a wired mouse, I will take it.
https://linustechtips.com/topic/1074961-wireless-mouse/
G602 is a fantastic wireless mouse. They go for 60 USD.
https://linustechtips.com/topic/1074961-wireless-mouse/#findComment-12663242
I really like my G403, it is a little heavy compared to a wired mouse ( its like 105 grams ) however you would have to buy it used though since brand new its crazy. I bought mine refurbished for like 39.99 it was a little scuffed but it has worked great for the pass year and a half.
Ex frequent user here, still check in here occasionally. I stopped being a weeb in 2018 lol
For a reply please quote or  @Eduard the weeb me :D
Xayah Main in Lol, trying to learn Drums and guitar. Know how to film do photography, can do basic video editing
https://linustechtips.com/topic/1074961-wireless-mouse/#findComment-12663268
Hey dude, the steelseries rival 650 new is $120, half that if used,.I would look into that. Also the mx master 2s, dark claw RGB, harpoon wireless, mamba, etc.
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
https://linustechtips.com/topic/1074961-wireless-mouse/#findComment-12663296
I have the Logitech G305. It has their lightspeed sensor, feels light to me (coming from a 2015 Razer Naga wired, so a lot of mice will feel light). It is the typical shape, long battery life (like up to 250 hours on 1 AA battery), has a DPI button, normal left and right clicks and a satifying click sound. I recommend it for sure. the logitech software to control this little guy isn't half bad. This mouse really helped my aim in Overwatch and the like without having a wire. It also comes with a dongle you can use as a USB extension to get the sensor closer to the mouse (I don't know if this actually affects anything but I use it and have no complaints).
My main gripes with it thus far, and these gripes aren't enough to make me not want to recommend it, is that 1 the battery is a AA battery and not a rechargeable one, but with 250 hours of battery life, or even half of that, you wont be changing out batteries too often. I often out of habit find myself turning off the mouse when I go to turn off the computer or end my session attached to the keyboard. And 2, it is a tad on the smaller side, granted I'm 6'3" so most items in an office setting feel small lol.
My First (Current) Build:
Ryzen 7 2700 (3.90 1.35v OC) | Asus Prime X470 Pro | G.Skill Ripjaws V 16gb 3200 | Inland Professional 512gb M.2 NVME | Samsung 860 Evo Sata M.2 1TB | Corsair H115i Platinum | Corsair ML 140 RGB Fans | Fractal Design Meshify C | EVGA RTX 2070 XC Ultra
Laptop:
HP Spectre X360 13t Gem Cut (i7 8565u, 240gb, 8gb mem)
My Ride:
2015 VW Golf TDI Sportwagen
Eventually an XJ manual...
https://linustechtips.com/topic/1074961-wireless-mouse/#findComment-12663377
