So my phone suddenly stopped charging at the speed at which it used to. Currently, it's charging at a rate of 5% per hour or so. You guys can guess how slow that is. Here's what I have found out till now. The input current never goes above 500ma. Previously, it used to charge at 1500-1700ma atleast using a 2A charger. The charger and the cable are new and works well. My redmi Note 3 get an input current of 1800-2000ma. I have tried many thing like completely draining the battery and charging again but it still is charging slow. I have tried calibrating my battery. No luck. I have even manually deleted the BATTERYSTATS.INI file. Hell, I have even reset the device today. It's frustrating me now.
https://linustechtips.com/topic/1074902-extremely-slow-charging/
Maybe the usb port on the phone is broken get that checked and if this doesnt fix it change the battery.
i had the same problem, suddenly my CABLE started moving around, because it was too big for the hole, so u should try smaller cable(this i mean the head of the cable)
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
