Need to know if Gigabyte or ASRock have software for Controlling Fans based on GPU temp
1 hour ago, LogicalDrm said:Software isn't the issue, the motherboards themselves are. And if mobo has chip for GPU temps or not, thats not easy thing to check. There would need to be someone with actual mobo to check if you can set GPU temp as sensor to be used.
My Gigabyte can do that, but I'm not sure if its universal feature for all of that brands mobos.
Most motherboards can detect GPU temp, thats why if you download something like HWinfo it will tell you the temperature your gpu is at, even some games Black Ops 4 for instance has a setting to display GPU temp on screen in game, it is actually a software issue, as the software needs to be able to grab those temperatures and allow you to set a fan curve to make Fans plugged into the motherboard that normally can only be controlled by CPU temp or user set constant RPM speed and instead have them make that curve off GPU temp, now a normal Overclocking program like MSI Afterburner can see those temps and change the speed of the fans that are actually on the GPU, but in this case i need to control fans that are connected to a motherboard not the GPU directly, There are 2 programs i know are able to set these curves, CAM from NZXT which requires the use of my NZXT GRID, or Speedfan which takes some time to set up as its not a straightforward proccess, i was trying to find out if any of the motherboard manufacturers have a program for it made for use on their motherboards so i could remove the grid, i posted this in the Motherboard forum as well and was told by a user of the gigabyte board that they know Smart Fan 5 does not but they are unsure of the ASRock board but doubt it, so Im going to say right here that my problem has been solved.
