Hey,
So pretty much, I was installing Cheat Engine, for some single player games made sure to decline all the junk apps they try to install but some how Chromium still got installed...At first I tried to remove the program from the "Add or Remove" thing on windows and when you clicked "Uninstall" it would load then nothing would happen, So I installed Malwarebytes and it seemed to to the trick, when I go to look for the file in Add or Remove its gone, Yet the issue I am having is when ever I turn my computer on Chromium pops up...
And If I look at "Startup" what boots up when my computer turns on Chromium is still there....
EDIT: Also if I right click it and hit File location this is what I get.
I REALLY dont want to do a clean install, due to I just did one like 2 weeks ago...
Anyone have any idea on how to remove it?
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/1074327-chromium-virus-help/
