Weird pc problem
Go to solution Solved by M0SIE,
I fixed it.I just removed the GPU sprayed air at the PCIe slot put it back and it worked
Check all connections, in and outside the case and make sure everything is properly plugged in.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1074171-weird-pc-problem/#findComment-12656446
Just now, M0SIE said:
Checked all pushed my gpu into the slot even more as long as the pc shakes theres this problem
But also all the cables? Also on the monitor side ?
https://linustechtips.com/topic/1074171-weird-pc-problem/#findComment-12656457
