Hi Everyone, I have a parts list and I really want to order these parts with in the two next weeks. I've been waiting for a couple of years to get this upgrade and I honestly can't wait. I want this PC to last me 3-4 years with 3440x1440p or 2560x1080p (34" Ultra wide). I'm in high school and wont be gaming much but when I do I want a decent experience and good value. If you have any better suggestions I'll be waiting for the two weeks and if it really seems worth it, up to Christmas sales. All prices CAD.
Parts List: https://ca.pcpartpicker.com/list/PtDMLJ
Current PC Specs:
R5 2600
MSI B450m Bazooka
GTX 750ti
16GB 3000Mhz Ram
500gb SSD
1Tb HDD
Coolermaster TC102 Combo
All help is appreciated and thank you.
https://linustechtips.com/topic/1074127-build-help-please-asap/
8 minutes ago, brob said:
Your motherboard is mATX so it will look a little small in an ATX case.
The RM550X is a little bit more expensive as is fully modular.
Any Case that is like the Deepcool Matrexx. I really like the look and features the case has.
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656051
1 minute ago, dgsddfgdfhgs said:
no need water cooling on ryzen , that saves you ~$70 on a good tower cooler or a better gpu - vega 56 / rtx2060.
Yes, but I also love the look of the Watercooler. I know it is dumb but these kind of things are very appealing to me.
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656094
2 minutes ago, brob said:
It is a nice looking case and seems to have good cooling. Definitely will consider!
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656099
29 minutes ago, Charmander said:
600$ CAD tops.
PCPartPicker Part List
Video Card: Zotac - GeForce RTX 2060 6 GB GAMING Video Card  ($459.00 @ Mike's Computer Shop)
Case: Cooler Master - MasterBox NR400 (w/ODD) MicroATX Mid Tower Case  ($74.25 @ Vuugo)
Power Supply: Corsair - CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($54.99 @ Canada Computers)
Total: $588.24
Generated by PCPartPicker 2019-06-18 22:46 EDT-0400
watercooling is completely unnecessary, if you really want looks that much then just grab a cheap RGB strip or RGB fans.
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656104
Total: $588.24
I guess performance is more important, and I can always get the AIO later. Thanks
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656113
Total: $588.24
Also, https://ca.pcpartpicker.com/product/kfWfrH/zotac-geforce-rtx-2060-6-gb-gaming-video-card-zt-t20600d-10m
this is the same price but seems to be better
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656115
Total: $588.24
Also, what about his case? https://ca.pcpartpicker.com/product/dgndnQ/thermaltake-versa-h18-tempered-glass-microatx-mini-tower-case-ca-1j4-00s1wn-01
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656155
1 hour ago, Charmander said:
600$ CAD tops.
I wish CAD prices are lower.
Yes it's over the Max of $600 CAD
Video Card: EVGA - GeForce RTX 2060 6 GB XC BLACK GAMING Video Card  ($459.99 @ Memory Express)
Case: Corsair - Carbide Series 275R ATX Mid Tower Case  ($69.99 @ Canada Computers)
Power Supply: Corsair - TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($89.99 @ Canada Computers)
Total: $619.97
Generated by PCPartPicker 2019-06-18 23:28 EDT-0400
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656169
Total: $619.97
Yea ik :(  but thanks for the help
https://linustechtips.com/topic/1074127-build-help-please-asap/#findComment-12656177
