2 minutes ago, thexandrew said:
-SNIP-
There would be no lighting control, all RGB or ARGB based fans require it to interface with some kind of controller let it be manual via remote or software controller.
And as it's basically a standard nowadays, almost every motherboard comes with LED controllers & connectors onboard.
The question is just whether they support the same or a similar standard. And that's where I'm out because I don't care about RGB.
