CPU FAN ERROR! HELP :(
Solved by WoodenMarker,
5 minutes ago, xxRainzeroxx said:How do i turn off the CPU FAN ERROR?
During boot, press the Delete key to enter the motherboard settings. Press F7 to enter Advanced Mode. The Wait for F1 Error option is under the Boot tab. Disable it and press F10 to save settings.
3 minutes ago, xxRainzeroxx said:My CPU temperature is 82F, my motherboard temperature is 82F, and PCH Temperature is 95F. Is that even normal?
My computer is pretty loud for no reason.
Yes, that's normal. We usually use Celsius though.
If your system is noisy, check to see where the noise is coming from. What rpm are your fans running at?
Please use the Edit button to add in info instead of making multiple posts -- posts merged.
