Hey! so i have a budget of £2000-£2200 to spend on a new pc BUT im stuck between what to get.
I want to do render work and graphics design but keep re-thinking my decisions.
With the new release of ryzen im planning on getting the ryzen 9 3900x for £390 msrp if im not mistaken but the motherboards i dont know the prices of.
the applications i use (blender, vegas pro, davinci resolve, games and a custom render program by one of my close mates that takes advantage of multi-gpu rendering)
thats where im stuck multi gpu or not.
if anyone could help create a parts list that would be amazing.
i would prefer 32gb of ram but 16gb is ok if it means better render performance.
thanks in advance :D
Arctic frost
my first build
cpu: intel i5 8600k
cpu cooler: ARCTIC - Freezer 33 eSports ONE
motherboard: Asus ROG strix z370-E
ram: Corsair - Vengeance LPX 16GB (4 x 4GB) DDR4-2133
ssd: Kingston - A400 240GB 2.5" Solid State Drive
hdd: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
gpu: Asus - GeForce GTX 1060 6GB Dual Series
case: NZXT - S340 Elite (White)
psu: EVGA - B3 550W 80+ Bronze
thanks to @seoz for helping make the list :P and its based of her custom rig
https://linustechtips.com/topic/1072043-new-build-help/
RGB? Preferred case, colour scheme, do you have monitor and what not already?
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12638965
at the moment i have a 1920x1080 monitor which isnt the best so if its not to bad of a performance impact a new monitor would be a happy adition, rgb i dont care, colour scheme white preferably but i dont really mind the case or anything just want raw performance and not to bothered about the looks as long as it isnt a really horrific case then im fine with whatever.
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12638973
If your'e focusing more one content creation it would be better to get an ultra-wide monitor, and since raw power is what u want ryzen in just fine, an Rtx  card is a great choice for gaming.
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12638985
Thats what i was thinking but im only good at creating parts lists never knowing if its compatable eg i was thinking ryzen 9, rtx 2080ti and stuff but then that eliminates the price for a monitor
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12638987
1 minute ago, Oalei said:
I would say get a Radeon VII and Ryzen 9 3950X, well it got 16gb and HBM2, rendering 3d modelling etc gonna benefit from it i think.
yes it would, but keep in mind that comes out in september. my current pc has broken so looking to buy it in august latest. the rtx 2080ti im pretty sure will have a better render speed (i may be mistaken just basing this off my friends rig) and would allow me to game with better performance.
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12638994
i was based of this
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639000
3 minutes ago, Oalei said:
i was based of this
havent watched all the way through yet but in the first 2 benchmark results rtx 2080ti is equal to the radeon and in the second its faster for youtube encoding. ill keep watching thanks for the link :D
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639005
Its highly dependant on the workload. The Rad 7 is for the most part a compute card. Keep ik mind you can almost get 2 of those for the same price.
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639010
yes but there comes a point of deminishing returns. crossfire is loosing supported programs and has a lot higher power draw so would require a bigger psu. yes i wont deny the radeon is a well performing card but from experience of owning both amd and nvidia cards nvidia is more optimised for programs. i would have to have parts lists that i can compare with benchmarks though to see what would be best for my specific workloads but im not the best at compatibility when it comes to parts lists.
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639020
also now questioning if i should get an i9 9900k instead due to some apps being able to benefit from integrated graphics+cpu+gpu rendering
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639031
i9 9900k is fair enough workstation for general person. over 8 core like threadripper it's to overkill (just good if used by coorporate)
vegas pro and davinci very suitable with amd graphics card.
maybe like this :
PCPartPicker Part List: https://uk.pcpartpicker.com/list/nCcQpG
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  (£462.98 @ Aria PC)
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler  (£131.48 @ Amazon UK)
Motherboard: Gigabyte - Z390 AORUS MASTER ATX LGA1151 Motherboard  (£240.02 @ CCL Computers)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 Memory  (£163.59 @ Amazon UK)
Storage: Intel - 660p Series 2 TB M.2-2280 Solid State Drive  (£191.48 @ CCL Computers)
Video Card: PowerColor - Radeon VII 16 GB Video Card  (£624.99 @ Amazon UK)
Case: RAIJINTEK - ASTERION PLUS ATX Full Tower Case  (£139.99 @ CCL Computers)
Power Supply: Corsair - AX 850 W 80+ Titanium Certified Fully Modular ATX Power Supply  (£195.46 @ Scan.co.uk)
Total: £2149.99
Generated by PCPartPicker 2019-06-12 12:55 BST+0100
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639070
maybe like this :
Total: £2149.99
i love the look of that parts list just questioning some parts.
with the cooler if i went for a slightly lower priced one and say an nzxt 500/500i would it make sense to get 64gb of ram instead of 32?
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639110
make sense too.
maybe some part going change :
CPU Cooler: Corsair - H115i PRO 55.4 CFM Liquid CPU Cooler  (£109.49 @ CCL Computers)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3000 Memory  (£131.58 @ Aria PC)
Case: NZXT - H500 ATX Mid Tower Case  (£69.99 @ Box Limited)
Total: £442.64
Generated by PCPartPicker 2019-06-12 14:50 BST+0100
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639137
Just now, ahmad13610 said:
make sense too. i9 9900k just 95W processor, even some cooling with price 20 bucks can handle it. at the end, depends you planning next time, want go little/medium/hard core overclock or maybe not going overclock. if some times want go to medium overclock, nzxt 500/500i is more than enough. then budget left can spend to 32gb ram more.
You are being serious with the 95W thing ? ? Oh Lord.
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639141
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor  (£261.98 @ Aria PC)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  (£67.11 @ CCL Computers)
Motherboard: Biostar - X470GT8 ATX AM4 Motherboard  (£153.18 @ Ebuyer)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3000 Memory  (£149.85 @ Amazon UK)
Storage: ADATA - XPG SX8200 Pro 1 TB M.2-2280 Solid State Drive  (£129.00 @ Box Limited)
Storage: Toshiba - P300 3 TB 3.5" 7200RPM Internal Hard Drive  (£64.75 @ CCL Computers)
Case: Corsair - Carbide Series 275R ATX Mid Tower Case  (£64.19 @ CCL Computers)
Power Supply: Corsair - RMx White (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£98.99 @ CCL Computers)
Monitor: LG - 27UD58-B 27.0" 3840x2160 60 Hz Monitor  (£321.47 @ Amazon UK)
Total: £1935.51
Generated by PCPartPicker 2019-06-12 14:43 BST+0100
ofc, wait for zen 2 before buying if possible.
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639280
I would ignore any advice from this Guy having seen some of his other suggested builds.
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12639385
fair point lmao ive been thinking about this over night and will sent the parts list i made in a few minutes as i want second opinions so i dont end up wastinga load of money on parts that are not the best
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12641657
95W 9900K? Lmfao is that guy serious and $20 cooler on a 9900K, hellooooo thermal throttling 9_9
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12641679
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  (£461.97 @ Aria PC)
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  (£62.24 @ CCL Computers)
Motherboard: Gigabyte - Z390 AORUS ULTRA ATX LGA1151 Motherboard  (£224.33 @ CCL Computers)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-2400 Memory  (£56.33 @ Egenisys)
Storage: Team - MS30 512 GB M.2-2280 Solid State Drive  (£54.78 @ More Computers)
Storage: Seagate - BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive  (£81.96 @ CCL Computers)
Video Card: Zotac - GeForce RTX 2080 Ti 11 GB Twin Video Card  (£954.05 @ Technextday)
Case: NZXT - H500 ATX Mid Tower Case  (£69.97 @ AWD-IT)
Power Supply: Cooler Master - MasterWatt 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  (£64.51 @ CCL Computers)
Total: £2086.47
Generated by PCPartPicker 2019-06-13 11:47 BST+0100
opinions on this one?
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12641813
I think you're better buying 2x 7200RPM 2TB Barracudas, or a single 3TB one than a 5400RPM one that is painfully slow
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12641828
fair, other than that is it a reasonable parts list? or would i be able to get more performance for the same price? (rendering, gaming)
Arctic frost
my first build
cpu: intel i5 8600k
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12641836
I would go with faster Ram. I don't know how well Ryzen would suit your programs but maybe worth looking into as you get more for your money that way.
Motherboard: Gigabyte - Z390 AORUS PRO WIFI ATX LGA1151 Motherboard  (£184.12 @ CCL Computers)
Storage: ADATA - XPG SX8200 Pro 512 GB M.2-2280 Solid State Drive  (£76.99 @ Box Limited)
Video Card: EVGA - GeForce RTX 2080 Ti 11 GB Black Video Card  (£1006.92 @ Technextday)
Case: Fractal Design - Meshify C ATX Mid Tower Case  (£75.00 @ Amazon UK)
Power Supply: Corsair - TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  (£59.04 @ CCL Computers)
Total: £2127.48
Generated by PCPartPicker 2019-06-13 12:04 BST+0100
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12641847
3TB 7.2k RPM Barracuda swapped in
Air cooling option (feel free to use your ML240 if you want an AIO)
Slightly cheaper motherboard that also comes with wireless
16GB 3000Mhz RAM instead of 2400Mhz
Fully-modular Corsair PSU, 80+ Gold
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  (£111.79 @ Aria PC)
Storage: Seagate - Barracuda 3 TB 3.5" 7200RPM Internal Hard Drive  (£81.53 @ Amazon UK)
Power Supply: Corsair - RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£94.00 @ AWD-IT)
Total: £2079.32
Generated by PCPartPicker 2019-06-13 12:05 BST+0100
https://linustechtips.com/topic/1072043-new-build-help/#findComment-12641850
