So I've been having issues with connecting to wifi networks with my android phone. It sees the network and says that its saved but it doesnt connect to it, and if I press the connect button it says connecting and then goes back to just saying saved. I have tested connecting to other networks but none works even though it works just fine for other devices. Sometimes  it does actually connect to it, but it disconnects almost immediately. I have tried rebooting it and then it stayed connected for a couple of minutes before it disconnected again. I have tested being right next to the router so I dont think that i'm too far away from it. Please help.
https://linustechtips.com/topic/1071980-android-wifi-issue/
Router Channel ? some channels have issues in certain models and country like for me 1-11 is good and above that some of my old devices used 4 software testing have issues picking up.
2.4mhz or 5mhz ? some devices have issues with 5g old models
Device Model ?
did you tried this https://www.wikihow.com/Reset-Network-Settings-on-Android
AMD Ryzen 7 9800X3D
Gigabyte X870E AORUS ELITE WiFi7
Thermalright Phantom Spirit 120 EVO
Lexar 32GB ARES RGB DDR5 RAM 7200MT/s CL34
1TB SAMSUNG 990 EVO Plus M.2 SSD
4TB SAMSUNG 990 EVO Plus M.2 SSD
Asus TUF 4070 TI Super OC
1StPlayer NGDP 1000W ATX 3.1 5.1
Antec Flux [Mid]
https://linustechtips.com/topic/1071980-android-wifi-issue/#findComment-12638560
7 hours ago, Norwegiantweaker said:
have you tried to delete the network on ur phone and reconnect ?
Yup, and I've also tried connecting to other networks
Device Model ?
I believe it's a 2.4mhz connection. I've got an LG g3 with Android 5.0. It can connect to WiFi but only for a short time before it disconnects again.. could it still be a problem with the WiFi channels if I can't connect to any WiFi? and if so, how do I fix it?
https://linustechtips.com/topic/1071980-android-wifi-issue/#findComment-12639180
please try channel 11 if possible, check that the device is not blocked on the router.
i had same issue with the V10 that never solved till this day, i do have G3 that i didn't used for a long time(but i don't remember WiFi connection issues).
try some of this suggestions maybe you already did but worth check again https://www.cnet.com/forums/discussions/how-to-fix-the-lg-g3-wi-fi-won-t-connect-or-dropping-634054/
Wifi Analyzer‏
https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer
AMD Ryzen 7 9800X3D
Antec Flux [Mid]
https://linustechtips.com/topic/1071980-android-wifi-issue/#findComment-12641390
Wifi Analyzer‏
I downloaded the WiFi analyzer app and it says the WiFi is already on channel 11. O have tried to connect to other WiFi networks as well so the phone being blocked from the router shouldn't be the issue I'm having? I also checked the comments on the forum thread you sent and someone there said that doing this had fixed their issue and then I realized that the WiFi module thing is right next to the camera and I've broken my camera lens so dust could maybe have come in there and it might be shorting something? I'll try disassembling it and see if that's the issue. Do you think that's a good idea?
https://linustechtips.com/topic/1071980-android-wifi-issue/#findComment-12641991
Did you see any drops while wifi analyzer running ? leave it for a few minutes and check the graphs.
Does he offer better channels? like 1 or 6?
did you disabled the power saving mode in the advanced wifi settings ?
the problem with LG is that its hard to replace (i dont recommend this company to anyone for personal use after the issues i had with the WiFi on the V10).
https://www.youtube.com/watch?v=Y3SHuJnXMaU
AMD Ryzen 7 9800X3D
Antec Flux [Mid]
https://linustechtips.com/topic/1071980-android-wifi-issue/#findComment-12642123
Which graphs do you mean? The only graphs that I can see are signal strength graphs? And I also don't feel like that's the problem since I'm having trouble using any WiFi network and I've tried different ones? I tried the thing in the video I attached in my previous post and the WiFi has been working for about ten minutes now without a problem. I'm really hoping it's fixed now..
https://linustechtips.com/topic/1071980-android-wifi-issue/#findComment-12642299
?cool hope it works out 4 you?
AMD Ryzen 7 9800X3D
Antec Flux [Mid]
https://linustechtips.com/topic/1071980-android-wifi-issue/#findComment-12648386
