Odd ram speed?
Go to solution Solved by f2bacon,
I was able to get it up to 3125 and that's good enough for me. I guess if it isn't working at recommended try bringing it down 1 notch?
So I was going benchmarking to make sure I get adequate performance from my ebay/craigslist build and I noticed userbenchmark shows my ddr4-3000mhz ram running at 2133mhz. I installed cpu-z and ended up with this.
Am I severely underclocked on my ram or am I reading things wrong?
https://www.userbenchmark.com/UserRun/17580878
https://pcpartpicker.com/list/qZYjmq
Thanks for any help!!
https://linustechtips.com/topic/1071873-odd-ram-speed/
Gotta enable XMP/DOCP in the BIOS or set the clocks manually
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12637589
CPUz tells you what your ram is really running at, while advertised speeds are really doubled of what they are running at because double data rate
eg, DDR3 1600MHz = 800mhz real clockspeed
your ram is running at 2133MHz for some reason, that is correct. in some systems, the RAM underclocks to save on power, try to see if the clockspeed is the same while doing something intensive
if it is, then you've got your ram set to 2133MHz. Your ram may be rated for 3000MHz, but it's not going to run at that unless you set it to 3000MHz via XMP I believe
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12637593
I set it to 3000mhz in xmp. The userbench score was from benchmarking so I would think it would push it. I was sorta worried it was because I was using ripjaws 4 and not 5
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12637608
I would go back into the BIOS and double check it's still enabled.
It can happen that the setting resets itself or didn't apply properly for some reason.
If that doesn't help you can also try a BIOS update and/or try one stick at a time.
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12637627
There actually was a bios rate, but even with the update now stuff is showing 2128mhz. I got this picture from bios since I'm not positive how to translate all this stuff (learned overclocking from youtube) so maybe I just have something set wrong? Also in cpu-z I noticed "dual" channel memory, even though I have 4 sticks. Is that normal? I thought it would be quad channel. It's reading all the sticks for 32gb? Maybe I'm just not familiar with this stuff
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12638536
Finally a breakthrough. 2 sticks gets me to 2992.86mhz. Checking the QVL for my mobo, the dual channel is supported, but no mention of the quad channel ripjaws 4.
I got this set cheap on ebay thinking I had it made. 3000mhz 4x8gb quad channel rules.
So now should I look into a quad set that would work? or 2x16gb? im not familiar with how ram works but i'm trying to figure out the next move
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12641567
Quad-channel is only for Threaripper and Intel HEDT/Xeons. Normal consumer chips (Ryzen, i3/5/7/9) are all just dual-channel.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12641571
So that's why I wasn't getting full speeds? Quad channel just won't work with ryzen 5, so I should get 2x16gb?
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12641591
You can still get the correct speed, it will just still be dual-channel as RAM slots usually go A1-B1-A2-B2 (A & B denoting the channels)
IIRC 1st gen Ryzen are a bit more picky when it comes to RAM speed. I mean if you need 32GB yeah 2x16 works too.
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12641601
Actually I see you have the same board as mine, may I suggest try running it at 2866 or 3200. I couldn't get my RAM to work at 3000Mhz XMP profile but it works with the 3200Mhz one.
And when I tried overclocking a single stick of 8GB DDR4, it went up from 2133 to 2866 and anything beyond it crapped itself or refused to POST.
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12641607
3 hours ago, f2bacon said:
all 4 wouldn't run at 3000mhz, that's why I started the thread.
and I'm surprised that setting xmp to 3200 actually works on dual channel.
but all 4 sticks doesn't let me run at anything besides 2133
The amount of RAM sticks don't determine the channel type.
4 sticks can still only run in dual channel mode.
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12642785
so then why would they not hit 3000mhz? i'm sure i'm not understanding this correctly. i think i found a pretty good deal on 2x16gb 3200mhz, so i think i'll do that and sell the 4x8gb 3000mhz kit
I don't know tbh.
Bad ram? Is your CPU overclocked? Any changes to any other frequencies or the RAM timings?
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12643218
1 hour ago, Senzelian said:
I don't know tbh.
Could just be bad ram. I'm gonna pick up a new pair.
Cpu is overclocked to 3.9ghz. No changes on ram besides changing xmp.
Actually I think I may have manually input the timings that it says on the sticks when I got them
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12643367
So I picked up a pair of Corsair sticks. CMK32GX4M2B3200C16. Won't run at 3200. If I set xmp for 3200 it sets to 2133. I got it to boot at 3125.88mhz. Am I not understanding something? Should I be looking up timing specifics or something? I thought I could overclock my ram to be a hair faster but I can't get anything to run at advertised speeds
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12644141
Run your CPU at stock speeds, or even better reset the CMOS and then try to run them at the advertised speed.
If it still doesn't work, then there's something wrong with your motherboard or CPU.
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12645573
Pulling the cmos battery for 10 seconds did nothing. Putting the CPU to stock did nothing. If I try and run at 3200 it defaults back to 2133. I'm running at 3125 but now rarely I'm seeing program crashes and more recently a windows crash.
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12646625
Does clearing the cmos/bios not delete the default user profiles? I can't figure out how to get this damn thing to read correctly. I almost wanna think it's a hardware issue or hardware incompatibility. Could that be a thing? I was able to run 2 sticks of 8gb at the advertised speed (2x8gb 3000mhz, but if i tried all 4 sticks to get it to 32gb it doesn't let me)
I was super careful to check compatibility between components, did i miss something?
https://linustechtips.com/topic/1071873-odd-ram-speed/#findComment-12656337
