Did you buy a 1060 3gb or 6gb.... (yes your most powerfull card should go in the first X16 slot on your mobo, second why the hell do you have a gtx 960 and a 1060 in your pc at the same time?
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
https://linustechtips.com/topic/1071805-i-need-help-pls/#findComment-12637026
Well what are you doing with two gpus from two different generations
Current main PC:
GPU: 7900XT
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
https://linustechtips.com/topic/1071805-i-need-help-pls/#findComment-12637033
YES BUT THATS NOT HOW IT WORKS YOUR 960 IS NOT AN EXPANSION CARD FOR VIDEO ITS A HOLE OTHER VIDEO CARD
Current main PC:
GPU: 7900XT
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
https://linustechtips.com/topic/1071805-i-need-help-pls/#findComment-12637095
