So I've been having issues with connecting to wifi networks with my android phone. It sees the network and says that its saved but it doesnt connect to it, and if I press the connect button it says connecting and then goes back to just saying saved. I have tested connecting to other networks but none works even though it works just fine for other devices. Sometimes  it does actually connect to it, but it disconnects almost imediately. I have tried rebooting it and then it stayed connected for a couple of minutes before it disconnected again. I have tested being right next to the router so I dont think that i'm too far away from it. Please help.
https://linustechtips.com/topic/1071768-wifi-problem/
In network settings, if it's a newer version of android you can reset your wifi/network settings with the reset network settings button. Also check for system updates.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1071768-wifi-problem/#findComment-12636780
It's Android 5.0.... so I can't unfortunately do that, but I've checked all WiFi settings and nothing seems to be wrong. There are also no software updates since it's so old..
https://linustechtips.com/topic/1071768-wifi-problem/#findComment-12636845
Factory reset. Seems extreme but there's clearly a bug in there somewhere, and if 5.0 doesn't have a network reset then that might be your only option.
TUF GT501 | Ryzen 5600X | 32GB RAM | 480GB SSD | GTX 980Ti Hybrid | TUF X570 Pro
https://linustechtips.com/topic/1071768-wifi-problem/#findComment-12643788
