Hello, I recently bought a ASRock Deskmini A300 (it takes SO-DIMM memory) and a Ryzen 2200g to go with it. In the bios I know I can choose either 1.2V or 1.35V for the ram. I can't seem to find any ddr4 SO-DIMM memory kits that use 1.35V by default. Is it ok to use 1.35V in ddr4 SO-DIMM memory that uses 1.2V by default?
Thank you
https://linustechtips.com/topic/1070063-so-dimm-voltage-question/
