Hi guys, I set my case fans to idle until the CPU gets to 50℃ but they spool up when the CPU hits 40℃. Is there a way to somehow re-calibrate this temperature sensor at all? In the BIOS the curve is set to start at 50℃ but in the command centre (a form of remote BIOS) it starts at 40℃.
Also, my neighbour has the same setup as me and his fans work as he has set them in the BIOS, so I'm a little confused as to why this is happening.
Regards
Jack
System specs;
* AMD 2700X
* MSI B450 carbon pro AC
* BIOS version 2018-12-26
Temp-sensing software;
* MSI Afterburner
* AMD RYZEN Master
* MSI Command centre
https://linustechtips.com/topic/1070053-temperature-sensor-faulty/
If you set up a curve with the software it will not save the settings after a restart, You must set a curve in Bios.
It happened to me also, as it's my first MSI board.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
I go into my BIOS, save a fan curve and exit. In the software it say that all fan curves are set 10 degrees lower than what I asked it to do in the BIOS.
Even when the fan curve is set to default it still shows up with the same discrepancy - attached.
SYSTEM_DEFAULT_TEPMS_MSI.pdf
Top pic - command center
Bottom pic - bios
I had this issue before I installed the software. My fans would be fine and then they would spool up just randomly due to temp spikes, so it literally sounded like it would spike to 50 degrees. Contacted AMD, they said it doesn't happen when doing desktop things like chrome and word so it must be the motherboard software, low and behold it is. MSI now have a slight grudge against me or they might just be as stumped as I am as I haven't had a reply from them in a few (working) days.
And yes, I have uninstalled all programs that use the temp sensor for the CPU.
