So I am wondering if all GPU waterblocks ment for 1080s compatible or not.
My card is the one shown here https://www.newegg.com/gigabyte-geforce-gtx-1080-gv-n1080ttoc-8gd/p/N82E16814125908
Then does anyone have good suggestions for waterblocks that are ment for I7 6700k.
https://linustechtips.com/topic/1069785-gpu-waterblocks-and-cpu-water-blocks/
No they aren’t all the same. Need to check the brand of block you want and see if it lists your card under the compatibility list.
There are a lot of cpu blocks. I recommend getting one that matches the gpu block. I get ek because I want it to look the same and not like some crap amazon build.
