Hey guys,
Anybody have any idea what this could be? I'm trying to rule everything out before I declare that my AIO is dead.
The cooler I currently have is a Corsair H80i V2
I have re-applied thermal paste multiple times, cleaned the radiator and fans and I'm just not having any luck at all.
I have attached screenshots of my case (So that you can see I have sufficient airflow) and I've attached a screenshot of me running valley with temps)
Any suggestions? Thanks
CPU: Intel Core i7-4790K | GPU: GTX 1080Ti | Case: Corsair 750D Airflow | Motherboard: ASUS Maximus Formula VI | RAM: 16GB Vengeance Pro | PSU: Corsair AX860
SSD/HDD(s): SAMSUNG 850 EVO 120GB, SAMSUNG PM830 256GB, SEAGATE 6TB | Optical Drive: Sony Optiarc AD-5280S CB-PLUS
https://linustechtips.com/topic/1069498-cpu-temperature-hitting-nearly-100c/
2 minutes ago, kyle_987 said:
Hey guys,
Put your finger on the top side of the CPU block and try to feel if its vibrating or if there's waterflow. Sounds like a dead CPU water pump to me.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
Holy crap! Prolonged exposure to those kinda temps could do some serious damage! If you have any other coolers laying around, maybe try using that (even if it’s just a stock cooler) to see if it is your AIO that’s dead? If you get lower temps with a stock cooler, your AIO is probably dead.
I got a ps5 and a pc pretty ballin
Just felt the top and definitely don't feel anything, the tubes also feel extremely hot to touch but the radiator is freezing cold and is blowing cold air out
An AIO with that small radiator is in my opinion useless compare to a same price air cooler like a Noctua NH-D15.
As for the issue, put your finger on the block as @BrinkGG said to feel if the pump is vibrating.....
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
You pump is probably dead......
Yeah AIO pump is dead.
If you're looking for a new cooler, Noctua NH-U12S is amazing and I recommend it over single rad water coolers. Even an NH-D14 if you feel like going a overkill.
Stille (Desktop)
Evoo Gaming 15"
Corsair has a 5 year warranty.  How old is that AIO?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
Definitely not 5 years old, and I still have the receipt somewhere, I'll probably get a replacement.. but I'll do that after I buy an NH-D15 and just sell the Corsair one, I'm done with AIO coolers for the foreseeable future this is the second I've had problems with.
I fiddled around with it and it looks like the 3 pin fan cable that powers the pump has a loose connection, when I moved it into a different position the pump gets power again. Just going to leave it into position until I order the Noctua one in a few days. I've seen only good reviews on the NH-D15 so hopefully it'll serve me better than this one has.
Thanks for the help guys.
