problems with vega 56
Go to solution Solved by Jon Jon,
Just now, RotatoGonzales said:
i updated it 3 days ago but i will look again thx :))
can i just go to ryzen master and just put the cpu on game mode manually when i want to game?
What have you tweaked in the BIOS?
You can do that.
Honestly, I would at this point:
  • Uninstall Ryzen Master
  • Set BIOS to Optimized Defaults
  • Run Benchmark
  • See if Results are the same
My experience with Ryzen Master wasn't great and I found it to be really buggy.
hey guys.. i bought a saphire vega 56 yesterday and undervolted it. it runs stable and all that.. its perfect.
BUT... it seems that my gpu cannot unleash the full potential.
I have a 8gb ddr4 ram 1066 (single 1x8 not 2x4) and a ryzen 5 1400.. in witcher 3 at max settings i get max 53 frames which is a bit dissappointing. on the unigine heaven bench i got 1842 points.
i noticed that when i played witcher 3 the textures wouldnt load rly fast with my high settings.  ( i see a geralt with no hair then it loads.trees arent there they stuck loading first etc..)
is the CPU the problem or the ram. the frames drop also rly fast like jumping from 34 to 40 then 50 to 42 etc.. and not just witcher but many many games. In Civilazation 5 i get only 30 fps at all max
if u have some advice for me it would be rly nice :)
thank you very much
https://linustechtips.com/topic/1069351-problems-with-vega-56/
thank you very much
Both your CPU and RAM are issues.   Single channel RAM is bad, get another 1x8 stick of the same.  Also it's 2133 MHz RAM, not 1066.  It's doubled for DDR.
I'd grab the RAM and it should help.  I'd upgrade the CPU as well, depending on budget limitations.
What country/state do you live?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12616187
Yeah, there's a lot wrong with the setup...
Your CPU isn't really that powerful and one of the cheaper Ryzens.
But the worst part is the Memory. That one really needs to go.
You need at least 2 Sticks of DDR4-2666, if possible DDR4-3000 or 3200...
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12616271
Can you run 3DMark Firestrike and Userbench benchmark?
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12616389
For the sake of everything that is holy, get yourself another stick of RAM.
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12616392
i did i got 10600 points on firestrike
on user benchmark it says EVERYTHING is underpreforming drastically. even my ssd and such.
userbench:
UserBenchmarks: Game 69%, Desk 41%, Work 41%
CPU: AMD Ryzen 5 1400 - 48.7%
GPU: AMD RX Vega 56 - 95.9%
SSD: Toshiba Q300 240GB - 71.7%
HDD: Samsung HD103SI 1TB - 35.8%
RAM: G.SKILL F4-2400C DDR4 1x8GB - 36.6%
MBD: MSI B350 PC MATE(MS-7A34)
i noticed my ram is 2400 but i checked on cpu-z it clearly says NB-Frequency and DRAM Frequency: 1064.5 MHz
on cpu-z ( ok i get now that this is doubled ddr thing)
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12616772
germany.. the ram prices are actually pretty low. 16gb ddr4 3200 (2x8) for 80 euro will buy these now.
thank you for the advice
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12616776
i would defnitionaly reccomd this.
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12616795
userbench:
Can you give link for the Firestrike result?
Your proc is severely underperform, average result is 67%. Check the real time clock speed while gaming with software like HWiNFO or MSI Afterburner.
As for your RAM maybe you can try manually set it to 2400mhz in BIOS.
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12617023
nah sry for now i only got the demo of it..i simply never needed to do these benchmarks before.
i bought now 16gb (2x8) ddr4 3200 ram.. i hope this will solve my problems a little. i will also google a ton about how to check the cpu and maybe fix some shit.
thank you for the help :))
i only got this but this will not help i think i will post it nontheless
Graphics score
17 123
Graphics test 1
70.95 FPS
Graphics test 2
78.31 FPS
Physics score
10 247
Physics test
32.53 FPS
Combined score
2 362
Combined test
10.99 FPS
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12617095
Graphics score
17 123
Graphics test 1
70.95 FPS
Graphics test 2
78.31 FPS
Physics score
10 247
Physics test
32.53 FPS
Combined score
2 362
Combined test
10.99 FPS
Yeah those are pretty low score for your system and i don't think 1x8GB is the cause of it. Report back the result with the new RAM kit.
This should be your reference score give or take 10%. https://www.3dmark.com/fs/17585456
PM me if you need extra help, i can remote to your PC and do some basic troubleshooting for you.
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12617153
i bought the 2x8 gb ram 3200 and it doesnt seem to make such an impact. on witcher 3 it runs more smoothly and the textures load a lot faster now but these framedrops are still there.
firestrike on 10900 points and unigine heaven bench at 1978 points.
is it rly the cpu is it THAT bad?? i mean i thought on most games cpu isnt so important and ryzen 5 1400 is budget but not THAT bad right?
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12624967
Did you enable XMP profile for the RAM? Is it actually running @3200mhz?
Frame drop will always be there in open world game when it try to stream assets.
I gonna need Graphic score, Physic score and Combined score instead of overall score to see which one is the problem. Overall score doesn't really tell any store other than telling your PC is underperforming.
Can you download HWiNFO and run it in Sensor mode and let it run in the background while you playing your game for 5mins or so? Then upload screenshot of the sensors for CPU frequency, GPU frequency, RAM frequency and VRAM frequency.
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12625003
thx for the advice... i hope these are the right sensors? ( images )1953828715_Screenshot(333).thumb.png.9c118c72e3fa0ceae4d13510ef86b430.png1953828715_Screenshot(333).thumb.png.9c118c72e3fa0ceae4d13510ef86b430.png1953828715_Screenshot(333).thumb.png.9c118c72e3fa0ceae4d13510ef86b430.png
UserBenchmarks: Game 66%, Desk 36%, Work 42%
CPU: AMD Ryzen 5 1400 - 41.5%
GPU: AMD RX Vega 56 - 102.7%
SSD: Toshiba Q300 240GB - 43.6%
HDD: Samsung HD103SI 1TB - 43.7%
RAM: G.SKILL Ripjaws V DDR4 3200 C16 2x8GB - 88.5%
background cpu : 66% btw?
gpu clock was btw 900 mhz avg.
i hope this is something u can work with?
thx for all u did :)))
OMG I POSTED IT 3 TIMES I M SRY ( i hope i will figure out how to delete it )
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12625158
It's going to sound weird, but check for a BIOS update.
It looks like your CPU is stuck at a low clock speed.
When I first built my rig, I had a similar problem where the multiplier would get wonky on boot with an overclock, especially with Ryzen Master, which would make my Ryzen 7 1700 run around the same clock speed locked.
Definitely go into your BIOS and update it.
I think that'll fix your problem.
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Logitech G502 Proteus Spectrum
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12625322
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12625336
You can do that.
  • Run Benchmark
Desktop:
Corsair RM850X
Elgato HD60 Pro
Logitech G903 Mouse
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12625341
Can you check Task Manager what process utilizing that CPU?
Can you bench again with Discord off? Or disable Discord Hardware Acceleration.
Your RAM is running at 3200mhz so that's good.
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12625540
You can do that.
  • Run Benchmark
ok will do now just wanting to update something
i was stuck at a blackscreen at boot without even managing to get into bios cause of ryzen master
after applied gamemode and forced restart i couldnt access the pc anymore so yeah its EXTREMELY buggy i guess
got it on after cmos reset and such but yeah uninstalled that shit instantly
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12626889
i checked and there are no processes running but the processes from windows. i also ran ccleaner and malewarebytes. i had everything disabled
benchmark results are basically the same
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12627596
Problem solved after you uninstalled Ryzen Master?
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12631361
thank you very much
So i got a saphire vega 56 with 2 sticks of ddr4 at 3333 and a ryzen 7 2700. I am also not able to get the full potential out of the games and are getting about half the fps of every other person with a vega 56. For instance i only have 100 fps on rainbow 6 when my 1060 is hitting 110fps. U noticed im only running at 60% utilization though so i did ddu and it didnt help what can i do to fix this
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12631816
i solved it after that and i noticed that somehow (maybe i was it myself long time ago) i had eh energy safe mode on windows on. i did it in the same time as the optimized default one so i dont know which one of these but after i did both of these 1. optimized defaults in bios and 2. energy mode to normal settings in windows i have a normal score in userbenchmark i guess. everything performing now way above average
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12633843
eh for me these worked ( basically read all the posts above these guys are blessings)
1. bios set optimzed defaults
2. my bios set my ddr4 3200 on something like 2133 so i had to set this xmp profile so it can run on 3200
3. haha look if ur energy settings on windows are normal not like dumb me
4. undervolt card
https://linustechtips.com/topic/1069351-problems-with-vega-56/#findComment-12633851
