So, I wanted to setup a Dual PC so will play better and feel more comfortable while streaming. I always notice that I play much better off stream.
From what I have been looking at there is no true way to stream without a performance dip except for a dual pc.
PCPartPicker Part List
Type Item Price
CPU AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor $145.00
Motherboard MSI - B450M PRO-M2 V2 Micro ATX AM4 Motherboard $105.00
Memory Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory Purchased For $0.00
Storage Intel - 545s 256 GB 2.5" Solid State Drive Purchased For $0.00
Case Cooler Master - MasterBox Lite 3.1 MicroATX Mid Tower Case $59.00
Power Supply Cooler Master - MWE 400 W 80+ Certified ATX Power Supply $55.00
  Prices include shipping, taxes, rebates, and discounts
  Total $364.00
  Generated by PCPartPicker 2019-06-02 17:05 AEST+1000
I already have the RAM and SSD, so I cant change them, I dont care too much about gaming performance or aesthetics. I was going to throw in an Elgato HD60 Pro and have it set as a fourth monitor mirroring the main monitor (because it doesnt support display port meaning that I cant get full resolution and full refresh rate).
The part that I am most confused about is sharing my devices. I have an AT2020+ USB Mic that I want to use on both PC's at once and I have a pair of Astro A40's that connect via AUX that I want to share. I am not sure if this is possible by just using splitters. I care more about sharing the mic rather then the headphones because I could probably do some russian engineering and use the casting pc as a microphone to my main PC.
If it costs too much I can just use a separate spare microphone.
Thanks for the help :)
idk tbh
https://linustechtips.com/topic/1069118-setting-up-dual-pc/
