So I just bought a rx 570 saphire. It is a second hand thou. My problem is when i connect my gpu to my monitor it has no signal.. but when I remove the gpu and directly connect it to my mobo it works just fine.. IS IT THE GPU IS BROKEN OR COMPATIBILITT ISSUE?
Specs;
Cpu :Intel core i7 2600k
Mobo: ecs 1155 h61h2-m2
4x2 1333mhz Ram
Psu: Corsair Vs450
The mobo is kinda old..  please help!
https://linustechtips.com/topic/1069084-help/
With the rx 570 card installed, do you get signal if  you connect the monitor to the motherboard?
If you do get signal you may need to go into the BIOS and look around for video output options. Some times the integrated graphics can be setup as the primary video out. Just switch that to auto and you should be good.
https://linustechtips.com/topic/1069084-help/#findComment-12613913
No sir, It has no signal. But the fan is spinning
https://linustechtips.com/topic/1069084-help/#findComment-12613960
Darn, that doesn't sounds very good.  Unfortunately I can't think of anything else to do for troubleshooting.  You may have a bad card :(.
The only thing else I can think of is maybe a power supply issue of some kind. But that is a long shot.
https://linustechtips.com/topic/1069084-help/#findComment-12616398
Dumb question, but did you connect PCIe cables to the card?
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1069084-help/#findComment-12616403
Oh I thought of one more thing you could try, but it is another long shot. Some times display port and HDMI don't work very well when posting. I am not sure what video outputs your using but if you happen to have a DVI cable and option on your monitor I would use that. For testing purposes.
Sorry I don't have better news :(
https://linustechtips.com/topic/1069084-help/#findComment-12616406
