So i just got a graphics card, like an hour ago, i plugged it in, great. Start my pc, pc is running, monitor isnt turning on, the monitor says no signal
This is an important note - i kept my monitor plugged in the motherboards vga slot because for the time being i do not own a dvi cable, well i do, but it doesnt plug in...so thats cool.
Specs -
I3-6100
RX560 4GB
8gb ballistix sports ram
A corsair 450w power supply
MSI h110m pro-vd motherboard
Any possible fixes i could try?
https://linustechtips.com/topic/1068735-no-signal/
Your computer will default to the GPU. You are not getting a signal because you still have the monitor plugged into the motherboard.
If you do not have a cable to connect the GPU and the monitor then you should just keep the GPU out of the system.
~Air Cooling Advocate~
https://linustechtips.com/topic/1068735-no-signal/#findComment-12611090
