hi all I'm building my first gaming pc (i have upgraded previous pc's so i somewhat know what im doing) and id like some more experienced builders in any advice they can provide in both the building process and the parts.
like I said I have upgraded pc's before so I know the basics and I've watched ltt,jay,bitwit and pauls videos on building a pc from scratch so I have an idea on what I'm doing.
the pc needs to be able to comfortably game at a decent frame rate on medium or higher graphic settings, I will be overclocking so I'm going ryzen as I want to be able to overclock without paying a premium for an unlocked cpu, it also will let me spend more money in other areas
my budget is around 1000 British pounds but I can go over slightly if needed, this needs to include the pc, monitor, keyboard and mouse
I already have bought( rounded prices)
cpu- ryzen 5 2600 £130
cpu cooler- hyper 212 rgb edition £40
memory-corsair vengeance ddr4 3000 2x8gb £77
parts I'm looking at buying(again prices are rounded)
mobo- msi tomahawk b450 £90
storage- 3tb segate barracuda £80(will upgrade with an ssd in the future)
gpu- msi Radeon rx580 8gb £167
case-cooler master pro 5 £70 (chosen as I want a case with both a side glass pannel and a see through or glass front pannel, the case doesn't need rgb fans but preferably does)
psu- corsair cxm 550 w 80+bronze £70
wifi adapter- Asus pce ac55bt £35 (wifi required as too far from router for Ethernet)
monitor - aoc 21.5" 1920x1080 75hz £83
keyboard- redragon k552 £33
mouse- Logitech- g502 proteus spectrum £60
and a next hue+ for £58 as this just brings me barely above budget but is not required if a better part can be purchased
any replacement part idea are appreciated as well as any tips for building as well as overclocking
thanks in advance
https://linustechtips.com/topic/1068367-first-pc-build-advice/
thanks in advance
If you include an SSD and drop the 212 cooler, actually looks really good.  People may quibble about brands for certain parts but overall it's great I think.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608204
pick up an X370-pro instead after confirming that it supports zen+ CPUs, better VRMs.
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608206
I forgot to plug in the 8-pin CPU connector and was wondering for hours why my PC wouldn't turn on. I also installed incompatible RAM and had a ton of BSoDs. So my advice to you is make sure you plug in both the 24-pin connector and 8-pin connector as well as have compatible RAM.
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608212
Gotta love when people reply with the entire OP.
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608214
Personally I don't care about which brand I choose so long as it works, cheers for the idea as well ill definitely think through it, I want to overclock though so will the stock cooler be able to handle it
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608219
The 2600 doesn't overclock all that well.  The stock cooler can handle it pretty well, and going beyond that really isn't worth it.
I think you'd get MUCH more benefit out of an SSD.  Use that $40 from the CPU cooler to get a nice 500GB boot SSD at the very least.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608233
I'd still go B450 over X370 based on B450 is guaranteed and X370 has to be confirmed.
Nothing wrong with B450 VRMs for mild overclocking at all.
According to Science Studio asking AMD about X370, check out the 8:00 minute mark. The BIOS ROM chip is too small to hold the BIOS revisions in some cases...
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608260
Honestly just leaving it to XFR instead of manually overclocking with stock is easier. Gets about the same frequencies
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608271
https://www.asus.com/News/EtaH71Hbjuio1arV asus has already confirmed support on the X370-pro and released the bios needed to support zen 2, plus the better VRM will help if he ends up getting a 12-core or so.
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608276
That's good to hear they're already working around it.
But why not move up to X470 then just to be safe?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608282
because i'm only recommending the X370-pro since it was just under 80 pounds.
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608295
I would Highly recommend an SSD now  and upgrade the cosmetics like RGB fans later. No SSD in 2019 would not be a good experience. even a small 120GB SATA SSD for your boot drive would be worth it and I bet you can find one cheap.
CPU i7 8700K ( 5 GHz) RAM G Skill Trident Z 32 GB (3200 MHz) GPU EVGA RTX 2080 XC Ultra Motherboard Asus ROG Strix z370 E Gaming Cooling NZXT Kraken x62 R2 PSU EVGA SuperNova 650 W 80+ Platinum Storage 500 GB Samsung 970 EVO NVME M.2, 1TB Samsung 860 EVO M.2, 1TB Samsung 850 EVO SATA, 1TB Samsung 860 EVO SATA Display Dell QHD 144Hz 27'' Case NZXT H500 Black Keyboard Corsair K95 RGB Platinum Mouse Logitech G900 Operating System Windows 10 Pro
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608777
Ok I'm looking at getting a 240gb Kingston SSD for about £25 and I can simply get the hue+ at a later date
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608822
I think that would be a smart plan. :)
https://linustechtips.com/topic/1068367-first-pc-build-advice/#findComment-12608896
