So I was thinking about using an SGI Onyx 2 Chassis to create one of the most ultimate sleeper builds of all time. The case in question is massive and is from 93’. Weighs in at 250lbs with all the pure original SGI parts in it. From videos I have seen of the case, it looks like you could easily fit up to 5 systems in it. 3 EATX systems and 2 mini itx systems if you play your cards right. Might b able to fit more, just gotta mix and match. Was wanting to use high end parts since the machine itself msrp’d for anywhere between 250,000$ and 654,000$ brand new back in the 90’s. Thinking Xeon W-3175X and a ThreadRipper 2990WX for the main systems and then 9th gen i9’s for the mini it’s systems. Maybe even a few Titan X’s? What are ya’ll’s thoughts on this? Honestly, I’d like to actually see this turned into a video but doubt that will happen.
https://linustechtips.com/topic/1068261-ultimate-sgi-sleeper-build-thoughts/
