Hi, so a while ago I bought a 2x8gb corsair vengeance rgb 4266 cl19. Then I realized my mobo (asus z370-e) can only support up to 4000mhz. So i enabled my xmp profile, left the timings as is, reduced the mhz down to 4000, and tried 3600 also. I cant seem to not get any memory errors running memtest, and sometimes ill get bsod while playing games. The highest voltage settings ive tried are 1.45v on ram, vccio/sa 1.25. XMP profile is 4266 19-26-26-46 @1.4v. These timings still cause issues at 4000, 3600mhz. Im not sure what other options I can try, any suggestions on how to get the most out of this kit? Im hoping to utilize 4000mhz or atleast 3600. My cpu is an 8700k @5ghz. bios is the latest version, not sure what to do/i have no idea how to fiddle with the more specific secondary/tertiary timings either. Any help is appreciated.
CPU: Intel i7 8700k || Motherboard: Asus Z370-E ROG || RAMCorsair 4266 2x8gb || GPU: Sapphire r9 280x tri-x || Case: Corsair 780t ||
Storage: Samsung 850 Evo 250GB, 1TB Segate Barracuda HDD || PSUSeasonic M12II Evo 850w || Display: AOC i2367FH 1920x1080p 23 Inch ||
CPU Cooler: Corsair h80 || KeyboardCorsair Strafe || MouseCorsair Scimitar || HeadsetHyper X Cloud II || OS: Windows 10 ||
https://linustechtips.com/topic/1067606-help-with-ram/
You sure you didn't just buy faulty ram?
https://linustechtips.com/topic/1067606-help-with-ram/#findComment-12601847
I'm not that good with memory overclocking, but something that's helped me with a mem oc in the past is to run the cpu at stock speeds while trying to dial in the ram. this will give the system more stability all together and make it a little easier to oc the ram. once you're happy with the ram and know it's stable, then oc the cpu again.
hopefully this helps you.
The Beast:
 i9 9900k (5.1Ghz all cores)
2080ti FE
32gb 2x16 trident z royal 3200c14
xi hero mobo
evga 1300 80+ gold
2x 1tb 970 pro
1tb 860 evo
6tb wd red
view 71 case
Custom loop (cpu & gpu)
420 & 360mm rads, ek water blocks.
asus PG279Q 27in 1440p 144hz ips gsync monitor
K70 mk2 k/b, G502 mouse, hyper x cloud revolver s headset.
(FOR SALE)
Sager NP8372
i7 7820hk, GTX 1070, 32gb ram, 17.3 in G sync display at 90hz. 500gb 960 evo. less than 1in thick.
Trident Z rgb 2x16 3200c14
https://linustechtips.com/main/topic/1066259-trident-z-rgb-2x16-3200c14-fs/
https://linustechtips.com/topic/1067606-help-with-ram/#findComment-12601853
yea its been a solid year, i had it at some low setting which was stable for a while, then i updated my bios and all my settings disappeared so i decided to try reoverclock it, running it at 2666 mhz seems to be fine but id like to shoot for higher mhz
https://linustechtips.com/topic/1067606-help-with-ram/#findComment-12601885
So ive tried lowering it to 3866mhz 20-26-26-46 2T which is xmp specs for 4266mhz. 1.45V vccio/sa 1.2/1.25. gets bsods
3600 same timings, bsods,
3200, same timings, bsods,
leaving it at stock without tuning 2133mhz cl 15 it seems to be fine, is my ram faulty? or did it become faulty? my mobo can support 4000, ram is rated at 4266, but it cant even get close with all the voltages high? any ideas?
https://linustechtips.com/topic/1067606-help-with-ram/#findComment-12606488
