Browsers audio drops out of sync
ant666_2
As the title states my browsers audio drops out of sync. The timing of it is random.
Things I have tried to resolve it already include
Disabling hardware acceleration
Updating nivida drivers
Updating browser
Unistallig java
Trying different resolutions.
Clearing C: space
The problem is limited to browsers (tested on Firefox and Edge) vlc works fine as does now tv (they use a proprietary player).
The only fix I have found is pausing and unpausing the video and that's only temporary, the problem comes back after a short while.
Thank you
Hello,
On my tablet i have the same problem from time to times. Solution i found is to restart the tablet. Are you on a desktop computer ? wired or wifi ? what is the cpu and ram you have ?
<<If you’re watching Netflix, it’s possible that it’s still using the Silverlight plugin, rather than the HTML5 player, and this is known to cause lip-sync problems.
Alternatively, check in the Control Panel under Sound and make sure no processing or effects are enabled which could cause a delay in audio.>>
https://www.techadvisor.co.uk/how-to/photo-video/how-fix-video-sync-problems-3668441/
9 minutes ago, chen57 said:
Hello,
Desktop windows 10
Wired
R1600 with 16gb 3000 ram
Nvidia gtx1060
Its unlikely I'm using silver light as I haven't installed it (manually at least) this installation. I'll check for processing effects. But wouldn't that affect the whole system rather than just the browser.
Unfortunately neither of these options worked. Thank you anyway
10 hours ago, chen57 said:
do you use aux cable, spdif or hdmi ?
I use hdmi, I tried spdif too and had the same problem
maybe try this ?
<<I just had this problem and after three days of googling, windows tinkering and some hair pulling, I finally fixed it. It seemed that the Atheros drivers for my WiFi adapter was the culprit. Even though I use the wired Broadcom connection, it had to be fully deactivated and the drivers uninstalled to stop interfering with my sound. I hope this helps you as well.>>
 https://forums.tomsguide.com/threads/audio-delay-over-hdmi-on-pc.446363/
On 5/28/2019 at 3:36 PM, chen57 said:
maybe try this ?
Nah that didn't work either, thank you anyway. I'm just going to do a clean install
