3 minutes ago, Remikp04 said:
a R5 1600 like mine
Ram speed matters too, and GPU of course. Also, what program are you using to measure usage?
Primary PC:
PSU tier list
How many watts do I need?
Just now, Remikp04 said:
MSI Afterburner. My ram is 2800MHz and GPU is GTX 1080 SC from EVGA but I play at low settings (competitive).
What changes about the CPU usage and framerate when you take the settings up a bit?
Primary PC:
PSU tier list
1 minute ago, jonjo said:
I have a Ryzen 5 1600 too, I just went into practice range and I also get about 20% CPU usage. I don't think it's cause for concern
How much FPS? Just when you spawn in dont move and the FPS there, mine is ~220 at ~20% usage
30% CPU usage may as well mean that ~3 of the 12 threads are maxed at 100%.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
I mean, it goes without saying but you just may not be capping it at all. It's not a big deal. Unless you have a monitor with that kind of refresh rates, the extra frames don't benefit you at all.
So, what's the monitor you are using?
Why are you concerned about the GPU usage when you're getting 220FPS?
I'm not sure why someone hasn't asked about that part yet (unless I missed it, I've been known to be quite blind at times).
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
  • 2 weeks later...
Sorry forgot I made this post. Thanks for the response. Basically, in game I get FPS drops to like 120 and sometimes it stays there and it feels a lot worse due it being a spike and yeah just feels horrible. And the GPU usage is proof that it's something to do with my CPU usage as usually my CPU can easily get 300FPS in practice range for other people and in game like 220FPS out of fights whilst I get like 170 max and in fights I hover anywhere from 120-150. While others gets like 180FPS minimum. So yeah im just confused as to where all that performance is going.
